Zyxel NR7101 Outdoor WiFi 6 NR 5G Router
The Zyxel NR7101 Outdoor WiFi 6 5G NR Router supports the latest 5G NR technology whilst at the same time retaining full compatibility with 4G/3G networks.
Lightning-fast internet connectivity
The Zyxel NR7101 has DL speeds higher than 5 Gbps and 4G LTE DL speeds of up to 2 Gbps. The wide spectrum bandwidth accelerates internet speeds and reduces network latency for premium and time-sensitive connectivity services.
Fixed Wireless Access (FWA)
Deploying the NR7101 as part of FWA allows you to extend your 5G service coverage into subscribers’ homes and workplaces without extra wire infrastructure. This secures the TCOs and increases business revenue by supporting a larger number of subscribers with a premium fixed-grade connection.
Easy installation and SA/NSA dual-mode compliant
The Zyxel NR7101 is equipped with a flexible wall or pole mounting kit, integrated IEEE 802.3at Power over Ethernet (PoE) support and dedicated WiFi AP with mobile apps content graphics for eNB/gNB alignment. The NR7101 is also interoperable with both Standalone (SA) and Non-Standalone (NSA) deployments.
Remote management and upgrade
Through the LTE radio interface, the NR7101 supports TR-069, remote GUI and FTP to be fully configurable. Firmware Over-The-Air (FOTA) support enables remote firmware upgrades and troubleshooting, through events triggered by the operators.
Environmental durability
With IP68-compliant K.21 6 KV/300 A lightning protection, the Zyxel NR7101 guarantees high-quality connections, a longer device life despite the weather and natural challenges. The NR7101 can operate within a wide range of temperature and humidity, which supports your service deployed in wide territorial scopes.
