Delivering wireless connectivity at speeds of up to 300 Mbps* with the 802.11n technology, the ZyXEL NBG-418N v2 Wireless N300 Home Router is a wide-coverage wireless solution ideal for homes. The NBG-418N v2 provides stable, reliable wireless connectivity for Web browsing, file exchange, media streaming and online gaming.
Benefits
Compliant with 802.11n with data transfer rates of up to 300 Mbps* With wireless speeds of up to 300 Mbps* thanks to the 802.11n technology, the ZyXEL NBG-418N v2 features bandwidth management that enables you to prioritize network traffics, making it ideal for streaming, online gaming and Web browsing throughout your home.
Two omni 5 dBi antennas for stable data transmission and wider coverage
With two omni 5 dBi antennas, the ZyXEL NBG-418N v2 provides a wider wireless range for you to enjoy wireless services throughout the home network and even in your backyard. You'll enjoy stable, reliable wireless connections for Web browsing, file exchange and multimedia streaming everywhere at home.
Wi-Fi Protected Setup (WPS) for quick, easy wireless security setup
The ZyXEL NBG-418N v2 features WPS that allows users to quickly establish network security simply by pressing the WPS button on the router.
Support for IPv6
The accelerated growth of Internet causes the limited IPv4 addresses to deplete shortly. As a result, many sites are now moving to IPv6 addresses; and the ZyXEL's NBG-418N v2 is the perfect choice for Web browsing today and in the future for its IPv6-readiness.
Online firmware upgrade service for feature enhancements
With just a click, you can upgrade the ZyXEL NBG-418N v2's firmware when updates or enhancements become available.
Eco-friendly router saves energy
The ZyXEL NBG-418N v2 features wireless scheduling and it can be configured to enable/disable wireless services according to your network usage needs. In addition, you can use the power on/off button on the rear panel to toggle wireless connectivity in a snap.
