Embrace GPU computing with Microsoft Windows 7 and the ZOTAC GeForce 210 Synergy Edition graphics card. Compatible with DirectCompute and NVIDIA CUDA technologies, the ZOTAC GeForce 210 Synergy Edition delivers phenomenal GPU computing power for a great performance value.
The ZOTAC GeForce 210 Synergy Edition is ready for high-definition video playback as well with NVIDIA PureVideo HD video processing, HDMI 1.3a support with xvYCC, Deep Color technologies and 7.1-channel digital surround sound audio output for a premiere high-definition video playback experience.
- Chipset Manufacturer: NVIDIA
- GPU: GeForce 210
- Core clock: 520MHz
- Stream Processors: 16
- Shader Clock: 1040 MHz;
- Memory Clock: 1066 MHz
- Memory Size: 1 GB
- Memory Interface: 64-bit
- Memory Type: DDR3
- 2 Year Manufacturers Warranty (extended to 5 Years if card is registered with Zotac within 14 days of purchase)
- Model: ZT-20313-10L
- Interface: PCI Express 2.0 x16 (Compatible with 1.1)
- Chipset: Manufacturer Nvidia, GPU GeForce 210, Core clock 520MHz, Stream Processors 16, Shader Clock 1040 MHz
- Memory: Memory Clock 1066 MHz, Memory Size 1 GB, Memory Interface 64-bit, Memory Type DDR3
- 3D API: DirectX DirectX 10.1, OpenGL OpenGL 3.2
- Ports: DVI 1(DVI-I), HDMI 1, VGA 1
- General: Tuner None, RAMDAC 400 MHz, Max Resolution 2560 x 1600, RoHS Compliant Yes, SLI Supported No, Cooler Passive (without fan), Dual-Link DVI Supported Yes, Windows Certified for Windows 7 with DirectCompute support
- Warranty: 2 Year Manufacturers Warranty (extended to 5 Years if card is registered with Zotac within 14 days of purchase)
