Look forward to a more productive working day with a Zoostorm Delta Micro PC.
When you're relied upon for administrative support in a busy office, school or business you need the best PC for the job.
The Zoostorm Delta Micro PC is designed and built for educational, commercial and industrial environments where your job involves constant multi-tasking.
Because computer-based tasks make up the major part of an office working day, you need to be confident it will never let you down. This PC starts up in seconds, quickly opening up all the files you need, the websites your researching and the presentations you're producing, ensuring no delays. This gives you more time to spend on the organisational aspects of your role and the unexpected urgent tasks which take up so much of your day.
Although modest in size, there is no skimping on performance. Thanks to the Intel Core i5 processor and 16GB RAM, The PC keeps working at full capacity and won't start to slow down just as you're completing your most urgent task. There is enough power to work all day on a multitude of tasks using the Zoostorm Delta Micro which will help you sail through your 'to do' list.
File sharing is easy. If you're asked for a quick copy of a file, you just slot in a USB stick to one of the 10 ports on the front and back. Four of the ports are the latest and faster USB 3.0 version. Use the DVD-RW drive to quickly copy video disks for sharing with your team.
Personal storage is available for you in the 256GB you have available to the safe keeping of your most-used files.
If your desk tends to become cluttered, you'll appreciate the extra space afforded by the ultra-slim Zoostorm Delta Micro, especially when you fit the monitor using a VESA mount. Its dimensions give you more room for non-PC based work.
Windows 10 Professional gives in-built assistance when you're searching for files and information. Like an extra pair of hands, the virtual assistant, Cortana, can be set up to remind you about important meetings and locating previously visited websites - a welcome resource in any busy office.
British made and put through stringent tests, Zoostorm PCs leave our factory only when 100% checked for quality. Our service includes the support of a UK based telephone helpline.
