Save time with the efficient, responsive Delta Elite Desktop PC.
Designed to reduce the administrative workload typically found in education and small businesses, the PC starts up quickly and gets to work without delay, sending numerous emails, opening presentations and retrieving all the information you need at your fingertips for the day's workload.
All busy educational, commercial and industrial environments need a computer that won't let them down. The Intel Pentium processor in this PC, and the 4GB RAM, gives you all-round reliable performance - you won't run the risk of the computer slowing down just when you're working to an urgent deadline.
For copying, sharing and attaching printers, storage drives and other devices there are 10 USB connections - located on the front and back. Two on the front (and back) are the latest USB 3.0 ports for faster data transfer. There's a rewritable disk for burning DVDs to allow you to share videos, photos and files with colleagues.
Storage on the hard disk gives you space for the files you need instantly when you need to get the job done faster.
Helping make it easier to locate information in portals, previously visited websites and directories is Cortana - the digital personal assistant that comes with Windows 10 Home. Set it up to give you reminders which will alert you to appointments and imminent deadlines.
Three audio jacks allow you to connect headphones, microphones or speakers.
Scratch-resistant paint protects the casing from damage in heavy-use environments in schools, offices and factories – and keeps it looking smart.
British made and put through stringent tests, Zoostorm PCs leave our factory only when 100% passed for quality. Our service includes the support of a UK based telephone helpline.
