Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3
80 PLUS Certification
80 PLUS Bronze
Input Voltage
AC 115-230 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output Current
+3.3V - 20 A / 0.1 A , +5V - 17 A / 0.2 A , +12V - 46 A / 0.5 A , -12V - 0.3 A / 0 A , +5VSB - 2.5 A / 0 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
Cable ties
15 cm x 14 cm x 8.6 cm
ATX12V 2.3
PSU Form Factor
ATX
Input Voltage
AC 115-230 V
Input Voltage Margin
+ 10% / - 10%
Frequency Required
50/60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output Current
Efficiency
88%
80 PLUS Bronze
Cable ties
Power cable - external
Cooling System
120 mm fan
Over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, Two-Forward Switching Circuit Design
