105°C solid capacitor guarantees stability at high temperatures, frequencies and currents. Built-in active PFC circuit provides high power factor and efficiency. Full bridge and LLC resonant circuits applied.
DC output modular cables to organize cables and for better efficiency.
High quality components
Active PFC and LCC resonant circuit
Secondary protection IC
Built-in circuits protects against voltage surges, current surges, power surges, low tension, short circuiting, and overheating.
Ultra quiet 140 mm for smart cooling
Smart fan control system optimizes thermal control while minimizing noise levels.
Flat type cable
Neatly organized flat-type modular cables help to increase air flow inside the case.
ZALMAN ZM1250 Platinum - power supply - 1250 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3
80 PLUS Certification
80 PLUS Platinum
Input Voltage
AC 115/230 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1250 Watt
Output Current
+3.3V - 25 A / 0 A , +5V - 25 A / 0 A , +12V1 - 45 A / 1 A , +12V2 - 65 A / 0 A , -12V - 0.8 A / 0 A , +5VSB - 4 A / 0 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x 4 PIN internal power , 1 x power 8 pin +12V with detachable 4 pin section , 1 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 1 x 8 pin PCI Express power with detachable 2 pin section
Modular Cable Management
Cooling System
140 mm fan
Cable ties, thumbscrews
15 cm x 20 cm x 8.6 cm
5-year warranty
ATX12V 2.3
PSU Form Factor
ATX
Input Voltage
AC 115/230 V
Input Voltage Range
AC 100 - 240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1250 Watt
Output Current
Efficiency
93%
80 PLUS Platinum
MTBF
100,000 hours
Cooling System
140 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, Quad SLI ready, CrossFireX ready
