| Quicklinx: | 82RXWS00 |
| Mfr#: | Z11-PLUS |
The front mesh bay cover provides cool air into the system while dust filters prevent dust from entering. It has interactive cooling system: Hot air generated from HDD is expelled through both sides. Cooling performance is maximized for HDD cooling, and the overall PC exhaust is increased. For user convenience, top air vents expel exhaustive air from the top cooling fan. In addition, translucent acryl vents are effective for tuning.
Front Mesh Cover for High Cooling Performance
Supports up to 7 System Fans
Up to 7 system fans are installed to expel hot air effectively from the case.
Zalman's Powerful HDD Cooling Solution
Interactive Cooling System : Hot air generated from HDD is expelled through both sides. Cooling Performance is maximized for HDD cooling, and the overall PC exhaust is increased.
Top Air Vent Exhaust/Tuning
For for user convenience, Top air vents expel exhaustive air from the top cooling fan. In addition, translucent acryl vents are effective for tuning.
Side-Panel Acryl Tuning
Dynamic Side Acryl Tuning is provided for users to view the interior of gaming system.
Supports Dual USB 3.0 Ports
I/O module provides dual USB 3.0 ports for user convenience and expandability.
Dust Filters for Front and Bottom of System and PSU
Dust filters in the front and bottom mesh covers prevent dust from entering the system and keep the internal components dust-free.
Additional Card Holder Provided
When installing VGA Card and PCI Slot, the bracket can be used permanently.
Supports Bottom PSU Installation and Aperture for Cable Management
Z11 Plus supports bottom PSU installation and provides an aperture for cable management to make better use of interior space.
Black Interior Coating
The interior of chassis is coated black to provide a sense of unity and elegant design.
Anti-Vibration Rubber Stand
Anti-Vibration Rubber prevents noise and also keeps the system safe from water or other liquid.
Tool Free HDD Installation with Anti-Vibration Rubber
The server-type Tool-Free HDD Mount Trays allow easy HDD installation/removal and maintenance
Spacious Interior for 290mm Card Installation
The interior has been designed to be spacious for easy installation and maintenance of various components.
Supports Solid-State Drive (SSD)
Space is provided on the back of M/B plate for installing 2.5" HDD/SSD. ? Use the bracket located on the 5.25" bay.
Separate Apertures for Convenient CPU Cooler Installation
Separate apertures for CPU cooler are provided for convenient CPU cooler installation without having to remove motherboard from case.
3-in-1 Bracket Provided
3IN1 Adapter Tray is provided for installing FDD / 3.5" HDD / 2.5" HDD/SSD
Rear Tube Apertures for Liquid Cooling Systems
Tube apertures are provided at the rear of the case for convenient water cooling set-up and maintenance.
Includes
