Quicklinx: | 9ST4WS00 |
Mfr#: | YCWHD6 |
See and hear exactly what your Y-cam Cube HD 720 does, from anywhere, with the cameras in-built professional quality, high definition 720p video. With the highest quality CMOS lens and microphone you can experience outstanding quality video with full resolution at 30 fps.
24/7 Protection
Experience 24/7 hours security with automatic IR cut filter for true day colour representation and instant activating 28 high powered infrared LED lights for crisp night time images, even in pitch black, for ultimate security through the day and night.
Motion detection & alarms
Easy to configure motion windows set through the camera user interface. Threshold and sensitive of these motions windows can be determined by the users offering total control The Y-cam Cube HD 720 intuitive system is able to send email notification, alerts and snapshot to any dedicated email account which will alert the users to any activity in real time no matter where the recipient may be.
H.264 Compression
The latest compression technology H.264 allows for the highest efficiency utilised network and reducing the need to extensive storage solutions, reducing costs and achieving a higher quality for less power.
Realistically bring true HD to the masses
Wi-Fi N
Utilising the most advanced Wi-Fi technology the Y-cam Cube HD 720 is our most connective camera to date. Housing Wi-Fi N compatibility users can now experience our widest and fastest connection speeds, insuring networks are optimised.
MicroSD recording
Capture every moment directly on your camera with the Y-cam Cube HD 720. Have the ability to store up to 64GB of data directly on the camera with the built-in microSD memory card slot. It doesn't need 3rd party software or recording devices or an internet connection so it can work in more remote locations.
Advanced compatibility
With absolutely is no requirement to purchase separate or dedicated 3rd party goods and the Y-cam Cube HD 720 grows works with the products you already own, and with our constant updates the Cube will grow with your system.
Direct iOS viewing
No need for fussy additional apps experience quality video and crisp audio, in real-time, from where ever you are straight from your phone or iPad.
Simple & Security
The camera compiles the latest encryptions including WEP/ WPA/ WPA2 for ultimate control and security however our intuitive interface means you get to implement the highest quality security with ease and efficiency.
PoE Accessory
Offering heightened flexibility, the Y-cam Cube HD 720 can connect to a simple plug in PoE accessory allowing users to switch between Wi-Fi and PoE, optimising installation possibilities and perfect for installers and end users alike that wish for a convertible and flexible solution.
WPS connection
Instantly connect you camera to your home Wi-Fi network. With the Cube built in WPS functionality you can connect you camera in seconds, making setup as easy as a push of a button.
Box Contains
Y-cam Cube HD 1080 camera
Camera stand/mount
3m power supply with UK/US/EU attachments
1m network (Ethernet) cable
Setup CD
Quick Start Guide
Micro-SD slot, WiFi, ethernet, IR cut filter, low-light & IR LED night-vision
