Taking perfection a notch higher with the stunning EVOL. Design.
90Hz FHD+ AMOLED Display
Display so fine, it will blow your mind. Brace yourself for an 11 on 10 viewing experience on the splendid AMOLED Display.
90Hz Refresh Rate - irresistibly smooth
High Refresh Rate of 90Hz means smoother scrolling and graphics resulting in outstanding user experience.
Sunlight Display
Designed to adjust your screen brightness according to the sunlight.
Reading Mode 3.0
Designed for eye comfort.
Qualcomm Snapdragon 680 - efficiency has a new name
Built on 6nm architecture, it is designed to give you superior performance while conserving power. Get ready for 11 on 10 experience!
Massive 5000mAh Battery 33W Pro Fast Charging - juice up in no time
With 33W Pro Fast Charging and 5000mAh Battery, get ultra-long battery life and improved charging efficiency.
Turn up the cool quotient
Consistent peak performance with Multiple graphite sheets for heat dissipation. More effective thermal conductivity with an upgraded cooling system and multiple layers of graphite sheets.
