The XFX WarPad™ isn't rough around the edges. This unique breakthrough in gaming technology is a mousepad designed to eliminate friction and discomfort during long or intensive gaming and working sessions. The XFX WarPad™ creates an edge so comfortable and supportive that your competition might just tire out before you do.
Effortlessly clamping onto any desk edge up to 2" thick and only requiring a 2" deep desktop lip to clamp onto, the XFX WarPad™ is easy to roll up and take anywhere you go. With it's unique clamping feature, you never have to worry about this mousepad sliding around.
This revolutionary mouse pad comes in at 16.97 inches x 13.98 inches. It's generous size helps to accommodate multi display gaming and projects. For gamers, by gamers, the XFX WarPad™ was meticulously developed by XFX's product developers to meet every intensive users' needs. The XFX WarPad™ has been tested and appraised by casual gamers, professionals, students and champions of the gaming scene to make sure that it has perfect ergonomics for any user.
If you want an edge in your gaming, but not the pain of feeling the edge of your gaming surface, the XFX WarPad™ is just what you've been wishing for.
The XFX WarPad™ features the Patent Pending Edgeless Support System™ (ESS) that angles and cushions your wrist and forearm during continuous mouse usage. No more dents under your forearms from that hard edge of your desk. It allows your wrist and forearm to glide seamlessly along it's tailored, smooth surface for optimum performance.
XFX WarPad Features:
The Three Layers - 1. Active Performance Fabric - 2. First layer of Styrene Butadiene Rubber - 3. Second layer of Styrene Butadiene Rubber
Thickest Soft Pad - 6mm thick pad with two actual layers of Styrene Butadiene Rubber is the thickest pad available today and is an ideal surface for extended gaming
Super XXL Size - This oversized surface comes in at 431mm x 355mm (16.97 x 13.98 inches). Thats 200mm longer than your average gaming mouse pad.
Performance Surface - Smooth Synthetic APF (Active Performance Fabric) surface is durable and finely knit unlike cotton surface that bubble and loosen. Ridged rubber matting for suprior grip and strength.
