- Manufacturer: XFX
- Chipset: Radeon R5 230
- Core Clock: 625 MHz
- Memory: 1GB
- Memory Bit Rate: 64 Bit
- Interface: PCIe 3.0 (x16)
- Streams: 80
- Cooling: Passive
- Connectivity: 1 x D-Sub, 1 x Dual Link DVI-D, 1 x HDMI
- Maximum Digital Resolution: 2560x1600
- Maximum VGA Resolution: 2048x1536
- Multi Monitor: 2 displays
- Low Profile Support: Yes
- Package Type: Retail
Fully supported Microsoft DirectX 11.2, with 4x faster tessellation rendering and massive virtual texture dynamic loading for more intense performance over earlier products.
See all your programs at the same time without having to switch. Be more productive and get more done quickly.
See all your track, equalizers, samples and editors all the same time. Be more productive and get more done quickly.
See more real-life peripheral vision around sides and see enemies you would have missed in single monitor.
- XFX Radeon R5 230 - Core Edition - graphics card - Radeon R5 230 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.1
- Graphics Engine
- AMD Radeon R5 230 - up to
- Memory
- 1 GB DDR3
- Core Clock
- 625 MHz
- Stream Processors
- 80
- Effective Memory Clock
- 1066 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
- Interfaces Details
- HDMI , DVI-D (dual link) , VGA
- API Supported
- DirectX 11.2
- Fanless
- 1.41 cm x 17.2 cm x 6.88 cm
- Graphics card - fanless
- Bus Type
- PCI Express 2.1
- Graphics Engine
- AMD Radeon R5 230
- Core Clock
- 625 MHz
- Stream Processors
- 80
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11.2
- AMD HD3D Technology, AMD PowerPlay technology, AMD Unified Video Decoder (UVD) 3, AMD Hybrid Graphics Technology, 3rd Generation TeraScale Engine
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1066 MHz
- Bus Width
- 64-bit
- Required Power Supply
- 400 W
- Included Accessories
- 2 low-profile brackets
- Software Included
- Drivers & Utilities
- RoHS
- 1.41 cm
- 17.2 cm
- 6.88 cm
