Quicklinx: | 95YQWS00 |
Mfr#: | 3615V_DN?GB |
The WorkCentre 3615 multifunction printer offers a full productivity toolbox in one device, so you're more efficient every day.
Productivity and Paper Handling
- A 60-sheet Duplex Automatic Document Feeder scans two-sided originals for copy, scan and fax jobs.
- The WorkCentre 3615 includes a 109 mm (4.3-inch) colour touch screen with easily understood instructions and help screens to streamline walkup operations.
- An easily accessible USB port allows users to quickly print from or scan to any standard USB memory device.
- 250-sheet output tray with tray-full sensor.
- 150-sheet Multipurpose Tray handles media sizes from 76 x 127 mm to 216 x 356 mm (3 x 5 in. to 8.5 x 14 in.).
- With the 550-sheet paper tray, standard paper capacity for the WorkCentre 3615 totals 700 sheets.
- Up to three optional 550-sheet paper trays increase total paper capacity to 2,350 sheets.
- Optional stand provides storage for toner cartridges, paper and other supplies.
- Place the WorkCentre 3615 anywhere you need it with the optional Wi-Fi Network Adapter.
Speed, Scanning and Print Quality
With best-in-class speed*, print resolution and media capacity, your busy office can deliver professional-looking prints, without waiting.
Built for speed.
Print up to 45 pages per minute (ppm) - the fastest monochrome print speed in its class*. Your first page prints in as few as 6.5 seconds.
True multifunction capability.
The intuitive 109 mm (4.3-inch) colour touch screen on the WorkCentre 3615 lets you program your next job while another is in progress.
Digitize...and simplify.
Easily turn cumbersome hard copy forms and documents into portable, digital files. Enjoy the added convenience of sharing your digital files automatically via email. You can even send your files to an established network folder or export them to any USB memory device.
Crisp details.
Bring definition and clarity to your documents with true print resolution of up to 1200 x 1200 dpi. Your printed communications never looked better.
* When compared to similar products as of September 2013.
Powerful Capabilities Built for Savings
Advanced tools improve security and save paper, power and time.
Reduce paper usage.
You'll dramatically lower your paper usage and related costs thanks to automatic two-sided printing. Plus, N-up printing enables you to print multiple pages on one sheet - a useful option when sharing presentations.
Increase efficiency.
Extra-high capacity toner cartridges allow you spend less time loading supplies and more time getting work done.
Keep information safe.
Secure Print keeps your sensitive documents out of the wrong hands by requiring users to enter a personal identification number at the device to print documents.
Use less power.
Unique Xerox® EA Toner fuses at a much lower temperature, reducing power consumption by up to 20% and CO2 emissions by up to 35%, compared to conventional toner.
All-in-one savings.
The WorkCentre 3615 combines the functions of a copier, printer, scanner and fax machine into a single, value-packed unit that can generate savings on energy and supplies costs.
Work From Anywhere.
When you're on the go, you can still print to the WorkCentre 3615, and manage it remotely from a web browser.
Print when and where you want.
With Apple® AirPrint™, you can print email, and important office documents, directly from your mobile iOS device when connected to your office Wi-Fi network.
And when working offsite, you can rely on Xerox® PrintBack to print documents back at the office so they are waiting for you when you return.
Freedom, unplugged.
With optional Wi-Fi capabilities, the WorkCentre 3615 is ready to go to work wherever it's needed.
Manage from a web browser.
Handle device administration remotely from any networked computer with Xerox® CentreWare® IS.
