The value of enhancing your company's image is immeasurable. And with the value-packed Phaser 6600 color printer, today's busy workgroups can easily make important business communications stand out from the competition with exceptional color printing.
Print Quality Features
- A print resolution of up to 600 x 600 x 4 dpi (1200 x 1200 enhanced image quality) makes your printed communications stand out and grab attention.
- Photo Mode makes your images and graphics look exceptional, producing deeper, richer colours for lifelike vibrancy.
- Unique Xerox EA Toner fuses at a much lower temperature, and reduces power consumption by up to 20% and C02 emissions by up to 35%, compared to conventional toner. It's also oil-free, delivering brilliant, glossy output, even on ordinary or recycled paper.
- Pantone® Colour calibrated solid-colour simulations and Xerox colour correction technology ensure results that match your expectations.
- True Adobe® PostScript® 3™ ensures your print jobs are consistently accurate, with the brightest, truest colours and superior graphics.
Productivity and Reliability Features
- A fast print speed of up to 35 ppm means your documents are always ready when you need them.
- Automatic duplex printing on the Phaser 6600DN configuration makes saving paper easy, and gives your documents a professional appearance.
- Print directly from Apple iOS-based devices with support for Apple AirPrint. (Requires firmware level 201301301313.)
- The main 550-sheet paper tray holds a full ream of paper. An optional 2nd tray increases total capacity up to 1,250 sheets for even longer periods of uninterrupted productivity.
- Keep your sensitive documents away from unintended recipients with available secure print*. *Requires Productivity Kit (with 512 MB RAM) or Productivity Kit (with 160 GB Hard Drive).
- A monthly duty cycle of up to 80,000 prints means heavy duty production.
Ease-of-use Features
- The Phaser 6600 is simple to install on your office network, getting you up and running in minutes. And with Xerox® CentreWare® IS, remote device administration is handled with ease right from any networked computer's browser.
- Place the Phaser 6600 anywhere in the office with optional Wi-Fi.
Enhanced output
Photo mode makes your images and graphics look exceptional, producing deeper, richer colors for lifelike vibrancy.
Unique Xerox EA toner
Fuses at a much lower temperature, and reduces power consumption by up to 20%, compared to conventional toner. It's also oil-free, delivering brilliant, glossy output, even on ordinary or recycled paper.
Always the right color
Pantone color calibrated solid-color simulations and Xerox color correction technology ensure results that match your expectations.
Consistent precision
True Adobe PostScript 3 ensures your print jobs are consistently accurate, with the brightest, truest colors and superior graphics. High-power capabilities the Phaser 6600 and delivers a host of capabilities and powerful options made affordable for small work teams.
Reduce your paper usage
Automatic two-sided printing on the DN configurations makes saving paper easy, and gives your documents a professional appearance. Plus, N-up printing lets you output multiple pages on one sheet, which is particularly useful when printing presentations.
Less to replace
High-capacity toner cartridges allow longer periods of uninterrupted productivity, and help you reduce your total cost of operation over time.
Stay secure
Keep your sensitive documents away from unintended recipients with available secure print, and protect access to device features with front-panel PIN code authentication.
Print and go
The Phaser 6600 works quickly, with color and black-and-white print speeds of up to 36 ppm.
Load paper less often
The main 550-sheet paper tray holds a full ream of paper - no more half-empty packages taking up valuable storage space. The total capacity up to 1250 sheets for even longer periods of uninterrupted productivity.
Xerox Phaser 6600DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
25.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Max Resolution (Colour)
1200 dpi
Automatic Duplexing
USB, Gigabit LAN
533 MHz
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PCL 5, PostScript 3, PCL 6, XPS
Media Type
Plain paper
Total Media Capacity
700 sheets
Media Handling
150-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
80000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
UNIX, Linux, Microsoft Windows XP or later, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver
1-year warranty
43 cm x 48.8 cm x 38.4 cm
Printer Type
Printer
Print Speed
Wired
USB, Gigabit LAN
1200 dpi
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Language Simulation
Colour Management Features
PANTONE Digital Color
Media Handling
533 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm)
700 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) , 1 x automatic - 550 sheets - Legal (216 x 356 mm)
Max Media Capacity
1250 sheets
Output Trays Capacity
250 sheets
Duty Cycle
80000 pages
Print server
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP 3
Security Protocols & Features
Apple Bonjour, IPsec, IP filtering
IEEE 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Power supply - internal
Frequency Required
50/60 Hz
535 Watt
Power Consumption Stand by / Sleep
65 Watt
Software Included
Drivers & Utilities, Xerox Global Print Driver, Xerox Mobile Express Driver
