Internal Wi-Fi connectivity comes standard for untethered mobility and the freedom to put your printer or multifunction device right where you need it. The Wi-Fi installation wizard and Wi-Fi Print Setup (WPS) make getting connected secure and simple. And, with Wi-Fi Direct, mobile devices can connect directly and securely.
Ready to pair
Now workers can easily print from mobile phone and tablets with Near Field Communication (NFC) tap-to-pair.
Multifunction productivity
The space-saving MFP helps you conserve energy and reduce supplies costs by combining the functions of a copier, printer, color scanner and fax into one affordable device.
Outstanding performance
With hefty processing power and standard memory, you'll see your first print faster and get high print speeds.
See the difference
Your documents will show exceptional sharpness with up to 1200 x 1200 DPI image quality.
Xerox Phaser 3330V_DNI - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
9.9 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi
AirPrint Enabled
1 GHz
RAM Installed (Max)
512 MB (512 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF, TIFF
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet bypass tray
Monthly Duty Cycle (max)
80000 pages
Print server
UNIX, Linux, Microsoft Windows Vista or later, Apple MacOS X 10.8 or later
1-year warranty
36.6 cm x 36.8 cm x 25.7 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wireless
AirPrint Enabled
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
Language Simulation
Media Handling
1 GHz
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 250 sheets - Legal (216 x 356 mm)
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
SSL, Apple Bonjour, WEP, TLS, WPA, IPsec, WPA2-PSK, AES, IP filtering, Wi-Fi Direct, WPA2-Enterprise
1 x USB 2.0 - 4 pin USB Type B ¦ 1 x Gigabit LAN - RJ-45
GOST, GS, Directive 1999/5/EC, FCC Part 68, R&TTE, UL 60950-1, IPv6 Ready, CSA C22.2 No. 60950-1-07 Second Edition, EMC 2004/108/EC, LVD 2006/95/EC, FCC Part 15 Class B
Power supply - internal
700 watt
Power Consumption Stand by
50 watt
Power Consumption Sleep
3.5 watt
Software Included
Xerox CentreWare Web, Xerox CentreWare Internet Services
