There are super powers packed in this small scanner. Capable of scanning a variety of documents, including long, small, thick and thin sheets, the DocuMate 5445 will greatly boost the efficiency of your office. Conveniently small enough to fit on a desktop, the scanner is designed to quickly scan ID cards and other documents, enabling real-time information sharing to provide fast, accurate customer service. The scanner has a convenient interface that allows the user to simply insert their document and press one button on the front panel to initiate scanning and automatically email, print, convert or share their document. Visioneer OneTouch provides scanning presets at the optimal resolution, color depth, file format and paper size for common scanning tasks, which can also be easily changed at any time.
Another unique feature of the DocuMate 5445 is the paper feed rollers. The rollers rotate independently left and right to reduce document skewing during scanning. In addition, the active double-feed prevention roller reverses rotation the instant that the leading document leaves the paper feed section to prevent the double-feeding of documents that are simply stuck together. However, there are documents for which scanning should not be stopped even when double-feeding is detected. Those include envelopes and documents with sticky notes attached. When the DocuMate 5445 pauses at one of these documents, scanning is easily resumed with the touch of a button.
