The ColorQube 8580 color printer is a powerful and an environmentally friendly printing solution that's simple and highly productive with the advantage of superior color output.
Solid Ink gives your documents rich, vibrant colors on all media, including recycled paper.
Wide media range
Print on everything from plain paper to labels, envelopes, card stock and business cards.
No time lost for color
The ColorQube 8580 prints black and white and color at the same fast speed.
Choose productivity
Add more memory to enable a variety of security and time-saving capabilities with a choice of two productivity kits.
Easy expandability
Adding additional media trays increases total media capacity up to 2,200 sheets for periods of high workload and enables multiple tray sources for your diverse office printing needs.
Small footprint
The ColorQube 8580 fits almost anywhere in your work space, whether on your desk or in a central location.
Earth Smart print driver settings
Easy-to-use print-driver gauge allows you to choose the most environmentally conscious print settings.
Up to 51 ppm - black fast , Up to 51 ppm - colour fast , Up to 30 ppm - B/W , Up to 30 ppm - colour , Up to 19 ppm - black laser quality , Up to 19 ppm - colour laser quality , Up to 6 ppm - black best , Up to 6 ppm - colour best
Image Enhancement Technology
FinePoint 2400
USB 2.0, Gigabit LAN
1 GHz
RAM Installed (Max)
1 GB (2 GB)
Language Simulation
PCL 5C, PostScript 3, PDF
Media Type
Envelopes, transparencies, labels, plain paper, card stock, punched paper
Total Media Capacity
625 sheets
Media Handling
100-sheet multipurpose tray, 525-sheet input tray
Monthly Duty Cycle (max)
85000 pages
Print server
UNIX, Microsoft Windows XP, HP-UX 11i, SunSoft Solaris 9, Microsoft Windows Server 2003, IBM AIX 5.x, SunSoft Solaris 10, Microsoft Windows 7, Red Hat Fedora Core 1, HP-UX 11, Novell Open Enterprise Server, Microsoft Windows Vista, IBM AIX 6.1 or later, Red Hat Fedora Core 5, SuSE Linux 10.x, Microsoft Windows Server 2008, SuSE Linux 11.x
1-year warranty
40.6 cm x 52.1 cm x 36.8 cm
Printer Type
Workgroup printer - solid ink - colour
Printer
Print Speed
Built-in Devices
Status LCD
Wired
FinePoint 2400
PostScript Support
Standard
First Print Out Time Colour
5 sec
Language Simulation
Colour Management Features
PANTONE Digital Color
Media Handling
1 GHz
RAM
RAM Installed (Max)
1 GB / 2 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), 76 x 127 mm
Media Weight
60 g/m² - 220 g/m²
625 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 525 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
2200 sheets
Output Trays Capacity
350 sheets
Duty Cycle
85000 pages
Print server
Remote Management Protocol
HTTPS
Security Protocols & Features
IPsec, 802.1x, IP filtering, SSL 3
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x solid ink (black) - up to 3200 pages ISO/IEC 24711 , 1 x solid ink (cyan) - up to 3200 pages ISO/IEC 24711 , 1 x solid ink (magenta) - up to 3200 pages ISO/IEC 24711 , 1 x solid ink (yellow) - up to 3200 pages ISO/IEC 24711
GOST, EN55024, EN55022 Class A, RoHS, UL 60950-1, EN 60950-1, FCC Part 15 A
Power supply - internal
Frequency Required
50/60 Hz
252 Watt
Power Consumption Stand by
104 Watt
Power Consumption Sleep
45 Watt
Software Included
Drivers & Utilities
