| Type: | Fax / copier / printer / scanner |
| Functionality: | Printer, Fax, Copier, Scanner |
| Max Paper Size: | Legal (216 x 356 mm), A4 (210 x 297 mm) |
| Quicklinx: | CHSDWS00 |
| Mfr#: | 6515V_N?GB |
Pursue relentlessly. Produce effortlessly.
That’s the way to build your business. Introducing the Xerox® Phaser® 6510DN Colour Printer – ready to work right out of the box. Fantastic image quality, easy connectivity, built-in productivity and reliability you can count on, at a price that won’t break the bank.
Spectacular Image Quality
Whatever your business, you’ll put your best face forward with our newest innovation in colour image quality.
Improved toner.
The Phaser 6510DN uses our new Xerox® EA Toner formulation, which has been reengineered for enhanced dot reproducibility and less toner waste. And because it melts at lower temperatures, it saves energy too.
Stunning resolution.
Smaller toner particles translate to finer details, and with 1200 x 2400 native dpi, your printed materials will capture attention and create greater impact.
Colour accuracy
PANTONE® Colour approved solid colour simulations and Xerox® colour correction technology ensure results that match your expectations.
Commanding Performance
Get a handle on day-to-day workloads with the powerful performance your business needs to grow and thrive.
Outstanding performance.
With print speeds up to 28 ppm, the 6510DN is perfectly positioned to support the demands of your growing business.
Print more for longer.
An optional second paper tray (not included) lets you load an extra 550 sheets at one time for extended interruption-free printing.
Time-Saving Taskmaster
Time is money, and these devices are purpose-built to save both by simplifying and automating costly, time-consuming tasks.
Easy management.
Our redesigned Embedded Web Server is easy to use and responsive, so you can easily manage your printer or multifunction printer at your desk or on the go.
Stay secure.
Keep your sensitive documents away from unintended recipients with the latest security features, including IPsec, SNMPv3, IP filtering and secure print.
