Featuring up to ten times the workload capacity of desktop drives, WD Gold hard drives are designed from the ground up for enterprise-class reliability, capacity, power efficiency and performance.
Delivering dependable performance to any storage environment, WD Gold hard drives are designed with a workload rating up to 550TB per year, among the highest of any 3.5-inch hard drive.
HelioSeal technology
Featured in over 15 million Western Digital hard drives shipped, HelioSeal technology allows for higher capacities and less turbulence on large storage arrays. And now on its 4th generation design, HelioSeal technology is field-tested and proven to deliver high capacity, reliability, and power efficiency you can trust.
Vibration protection
Enhanced RAFF technology uses sophisticated electronics to monitor the drive and correct linear and rotational vibrations in real time for improved performance versus WD's desktop drives in high-vibration environments.
RAID-specific, time-limited error recovery
Time-limited error recovery helps to reduce drive fallout within a storage environment caused by the extended hard drive error-recovery processes common to desktop drives.
Dynamic fly height technology
Each read-write head's fly height is adjusted in real time to ensure consistent performance for reduced errors and optimized reliability.
WD Gold WD8003FRYZ - hard drive - 8 TB - SATA 6Gb/s
