My Book® Desktop Storage: USB 3.0 and USB 2.0
Complete backup and security. My Book® desktop storage delivers optimized USB 3.0 data transfer rates and a complete backup solution to protect your precious memories and critical system files. Password protection with hardware encryption secures your private files.
Up to 3x faster transfer rates - My Book desktop storage is optimized for the fastest possible data transfer rates. Connect this drive to a SuperSpeed USB 3.0 port to access and save files up to 3x faster than USB 2.0.
Universal connectivity - With this drive you get compatibility with the latest USB 3.0 devices and backward compatibility with USB 2.0 devices as well.
Local and cloud backup - WD SmartWare Pro automatic backup software lets you choose when and where you back up your files.
- Choose scheduled backup to back up your files on the schedule that fits your needs.
- Choose automatic, continuous backup to back up files as they are added or changed and saved.
- Use your Dropbox™ account to back up your files to the cloud.
Dropbox account is required for cloud backup. Cloud services may be changed, terminated or interrupted at any time and may vary by country.
System-level backup - Acronis True Image WD Edition is an integrated software suite that ensures security of all information on your PC. It can backup the entire disk drive or selected partitions, including your operating system, applications, settings and all of your data. You can also use the software to securely delete any confidential data you no longer need.
Secure your files - WD Security™ utility allows you to set password protection and hardware encryption for your drive to help keep your private stuff private.
WD Drive Utilities™ software - Register your drive, set drive timer, run diagnostics and more using WD Drive Utilities.
Works great with Windows® 8 - The WD Windows 8 app makes it easy to discover the digital media stored on your My Passport Ultra drive with your Windows 8 computer. Your content is automatically displayed and organized so you can easily locate and enjoy your photos, videos and music.
WD quality inside and out - We know your data is important to you. So we build the drive inside to our demanding requirements for durability, shock tolerance and long-term reliability. Then, we protect the drive with a durable enclosure designed for beauty.
Ideal For
- Transferring fles with blazing-fast USB 3.0 transfer rates
- Backing up your files to the local drive with WD SmartWare Pro automatic backup software
- Backing up your files to your Dropbox™ folder
- Protecting your system-level files with Acronis® True Image WD Edition backup software
- Using with WD's free Windows 8 app to quickly discover your media files
- Connecting your USB 3.0 and USB 2.0 devices
- Securing your data with password protection and hardware encryption
- Adding extra storage for your videos, music, photos and files
Notes
- Formatted NTFS for Windows® XP, Vista, Windows 7, Windows 8
- Requires reformatting for Mac® OS X
- 2-year limited warranty - PanAm / EMEA
Kit Contains
- Desktop hard drive
- USB 3.0 cable
- AC adapter
- WD SmartWare Pro software
- Quick Install Guide
