My Book® for Mac® desktop storage features ultra-fast USB 3.0 connectivity, is formatted for Mac, compatible with Apple® Time Machine®, and offers password protection with hardware encryption.
Ultra-fast transfer rates - My Book for Mac desktop storage features SuperSpeed USB 3.0 for ultra-fast data transfer rates. Connect this drive to a SuperSpeed USB 3.0 port to access and save files in record time.
Universal connectivity - With this drive you get connectivity with the latest USB 3.0 devices as well as backward compatibility with USB 2.0 devices.
High capacity in a sleek design- With up to 3 TB capacity, there's plenty of room to store and protect your creative endeavors and your photos, videos and music.
Fast, seamless Time Machine backup - Back up your files quickly and easily with Apple Time Machine.
HFS+ Journaled - Works right out of the box with Max OS X 10.5 or later operating systems. Can be reformatted for Windows operating systems.
WD Security™ - WD Security software allows you to set password protection and hardware encryption for your drive to protect your files from unauthorized use or access.
WD Drive Utilities™ - Register your drive, set drive timer, run diagnostics and more using WD Drive Utilities.
WD quality inside and out - We know your data is important to you. So we build the drive inside to our demanding requirements for durability, shock tolerance and long-term reliability. Then, we protect the drive with a durable enclosure designed for beauty.
- Ultra-fast USB 3.0 connectivity
- Compatible with Apple Time Machine
- Password protection with hardware encryption
Ideal For
- Transferring files in blazing fast USB 3.0 speed
- Backing up your files with Apple Time Machine
- Securing private or sensitive data with password protection and hardware encryption
- Adding extra storage space for photos, videos and music
Kit Contents
- Desktop hard drive
- USB cable
- AC adapter
- Quick Install Guide
Notes
- Formatted HFS + Journaled for Mac OS X, Snow Leopard™, Lion™ or Mountain Lion™
- Requires reformatting for Windows® operating systems Note: Compatibility may vary depending on user's hardware configuration and operating system
- 3-year limited warranty worldwide
