A SATA III Internal SSD is Ideal for Any NAS Array
The WD Red™ SA500 NAS SATA SSD is an ideal choice for NAS arrays that operate in an always-on, 24/7 environment. Specifically designed and tested for the harsh conditions of a NAS array, WD Red SSDs feature advanced caching to handle even the most demanding applications.
Fast, Reliable SATA III Storage
A WD Red™ SA500 NAS SATA SSD can enhance your NAS’s response time. Efficient caching of big files makes the WD Red SSD ideal for OLTP databases, multi-user environments, photo rendering, 4k and 8k video editing and more.
Blazing-Fast File Access
WD Red SSDs are optimized for fast file access and can cache your most frequently used data for even faster access.
The Endurance of SSD
Because WD Red SSDs have no moving parts, there’s less to wear out over time – heat and vibration are reduced as well.
Work Faster and Save Time
Western Digital® 3D NAND, the WD Red™ SSD delivers outstanding SATA III performance to accelerate your productivity and save you time.
Intense Apps are No Problem
HD Video, 4K and 8K formats require a fast drive that reduces latency for hassle-free editing and transfer of huge multimedia files.
