The Se is best suited for bulk cloud storage, replicated environments, content delivery networks (CDNs), and SMB network attached storage (NAS), backup and archiving.
Get the right blend of performance, reliability and capacity and keep your total cost of ownership low.
24 x 7 x 365 reliability
Choose the storage foundation specifically designed for SMB to high-end NAS and large-scale datacenter replication environments running 24 x 7 x 365.
Designed for quality and reliability
All drives undergo at least 5 million hours of functional testing, and over 20 million hours of additional testing under actual workloads in actual server and storage systems.
RAFF rotational vibration cancellation technology
Enhanced Rotary Acceleration Feed Forward (RAFF) technology includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration in real time. The result is a significant performance improvement in high vibration environments over the previous generation of drives.
Dual actuator technology
A head positioning system with two actuators that improves positional accuracy over the data track(s). The primary actuator provides coarse displacement using conventional electromagnetic actuator principles. The secondary actuator uses piezoelectric motion to fine tune the head positioning to a higher degree of accuracy.
StableTrac
The motor shaft is secured at both ends to reduce system-induced vibration and stabilize platters for accurate tracking during read and write operations.
Multi-axis shock sensor
Automatically detects the subtlest shock events and compensates to protect the data.
RAID-specific, time-limited error recovery (TLER)
Prevents drive fallout caused by the extended hard drive error-recovery processes common to desktop drives.
NoTouch ramp load technology
The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
Thermal extended burn-in test
Each drive is put through extended burn-in testing with thermal cycling to ensure reliable operation.
Dynamic fly height technology
Each read-write head's fly height is adjusted in real time for optimum reliability.
