My Passport Slim is the ideal companion for your Ultrabook or other slim notebook. Thin enough to fit in your briefcase, pocket or purse, it's big enough to carry all your digital content.
When connected to a USB 3.0 port, My Passport Slim lets you access and save files in blazing speed. Reduce transfer time by up to three times when compared to USB 2.0 transfer rates.
Automatic backup software
WD SmartWare Pro automatic backup software works quietly in the background to help protect your data using minimal PC resources. Select automatic, continuous backup to instantly back up your files. Or select the scheduled backup option to back up your files on your schedule and take control of your backup.
Local and cloud backup
WD SmartWare Pro automatic backup software lets you chose when and where you back up your files. Choose scheduled backup to back up files on the schedule that works best for you. Choose file or folder backup if that is your preference. Use your Dropbox account to back up your files to the cloud.
Works great with Windows 8
The WD Windows 8 app makes it easy to discover the digital media stored on your My Passport Slim drive with your Windows 8 computer. Your content is automatically displayed and organized so you can easily locate and enjoy your photos, videos and music.
USB 3.0 and USB 2.0 compatibility
With this single drive you get compatibility with the latest USB 3.0 devices and backward compatibility with USB 2.0 devices as well.
WD Drive Utilities
Register your drive, set drive timer, run diagnostics and more using WD Drive Utilities.
USB-powered
Powered directly from the USB port on your PC. No separate power supply is needed.
Durable enclosure protects the drive inside
Your data is important to you. The drive is built inside to the demanding requirements for durability, shock tolerance, and long-term reliability. The drive is protected with a durable enclosure designed for beauty.
WD My Passport Ultra Metal Edition WDBTYH0010BBA - hard drive - 1 TB - USB 3.0
