            The Wasp WWS750 2D Wireless industrial barcode scanner is built for the harshest and most demanding applications in warehousing, transportation and logistics, and manufacturing industries. Its omnidirectional reading capability, four dot aiming system that provides quick and accurate scans and the freedom to roam with Bluetooth wireless connectivity that exceeds far from the base, make this 2D USB scanner kit a preferred scanning solution.
As innovative as it is rugged, the Wasp WWS750 delivers the ergonomic and operational features required for scan-intensive industrial applications. It operates in a wide range of temperatures, has a water and particulate sealing rating of IP65 and maintains its reliability even when subjected to repeated drops on concrete.
The Wasp WWS750 possesses advanced features to excel in the most demanding environments: "Liquid lens" that adapts and focus at different distances; this provides a versatile optic that is able to fulfill any scanning need with a single scanner; the user replaceable lithium-ion battery will provide power for long work. The WWS750 is also Bluetooth 3.0 compliant and features 3 Green Light technology and loud beeper for good-read feedback.
