Designed for creativity
This pen tablet combines Wacom's finest pen capabilities with intuitive
multi-touch support. Gain precision and control, speed your workflow, and
take advantage of all the pressure-sensitive capabilities in your favorite
creative software, thanks to the innovations built into the Intuos Pro.
Let pressure sensitivity power your creative toolbox
The Intuos Pro creative pen tablet delivers 2048 levels of pen pressure
sensitivity and tilt recognition, so you can create with the accuracy and
precision of traditional brushes and pens. Control line width and opacity
based on how lightly you touch the pen to the tablet surface.
Control & comfort you can feel
The combination of pressure-sensitive pen input with multi-touch gesture
support delivers a more fluid, more enjoyable experience as you create. Pan,
zoom, and navigate naturally with gestures on the multi-touch surface of the
Intuos Pro. Create and access your own multi-touch shortcuts. Enjoy the
comfort of the Wacom Grip Pen.
Efficiency at your fingertips
The customizable ExpressKeys™ and Touch Ring on Intuos Pro give you quick
access to your favorite software shortcuts. The pen tablet recognizes
application-specific shortcuts that you define. The on-screen Radial menu
and Express View heads-up display help you stay focused on your work.
