Vision's Media Players use Intel processors and are full-powered PCs optimized for digital signage applications - all in a tiny 4 x 4" enclosure. Display outputs depend on the processor chosen.
In the context of computers, Vision's media players are full powered computers in very small chassis. Until now the only very small PCs you could get have been slim-clients which have reduced processing power and functionality, but the VMP is even smaller than these and does not compromise on power.
More than a media player
They can be used in offices to replace old computers or at home as shared PC or media center for your home cinema. Do your e-mails, spreadsheets, social networking, stream media, and update codec - just as you would do on a normal computer.
Rugged 24/7
With a super-quiet fan and low power consumption the media player is designed to work seven days a week.
Fast boot
Includes advanced Intel features such as fast boot, BIOS Vault technology and Visual BIOS. Remote monitoring and access are possible and the i5 has Intel vPro technology which adds advanced layers of IT security management.
Vision Media Player - digital signage player
Digital signage player
11.7 cm x 11.2 cm x 3.9 cm
Intel Core i3 i3-3217U 1.8 GHz Dual-Core x 1
RAM
2 GB
Hard Drive
60 GB
OS Provided
No operating system
Mounting kit
11.7 cm
11.2 cm
3.9 cm
OS Provided
No operating system
Key Features
Digital audio player, digital photo viewer, digital video player
