Vision CS-1600 ceiling mounted speakers are passive 8-ohm low impedance speakers vision CS-1600 don't sacrifice frequency range in the way that the transformer on 100/70 V speakers inherently do, meaning lower bass extension and higher treble without distortion.
Powerful and robust 30 W power handling from the vision CS-1600 translates into loud sound with no distortion and with a frequency response of 80 Hz -20 kHz response the 2-way design offers full-bandwidth delivery with control and clarity.
Improved crossover design on the vision CS-1600 provides superb off-axis dispersion characteristics. Ceiling speakers inherently lack power at the bottom end, so Vision CS-1600 have been tuned to have a slightly louder sensitivity of 89 dB to punch through high-noise environments. The 6.5" woofer of the CS-1600 is a 6.5" polypropylene cone with a 3/4" Ferro-fluid cooled silk tweeter set in a swivel mount for fine tuning of the stereoscopic image.
The Vision CS-1600 speaker is designed for unobtrusive sound dispersion whilst mounted flush into false ceilings and ceiling tiles or deep custom made plaster board cavity walls, a perfect alternative for situations where wall speakers are not appropriate.
