ViewSonic's VP2772 is a 27" ultra-high resolution display with 2560 x 1440 QHD resolution and 10-bit color. Covering 99% of the Adobe RGB color space, the VP2772 meets the high color standards of photographers, graphic designers, video editors, print departments, and other design professionals. With its advanced 12-bit color engine and 14-bit LUT, the VP2772 smoothly processes, grades, and renders 68.7 billion colors to create stunning images with rich depth and detail. Equipped with dual DisplayPort inputs and one DisplayPort output, it allows one image source to be shown simultaneously on multiple daisy-chained displays without any difference in color. In addition, HDMI and DVI inputs, and four USB 3.0 ports let users connect with multimedia and storage devices. The VP2772 is also ergonomically designed with tilt, pivot, swivel and height adjustments to create a more comfortable and efficient working environment. The ViewSonic VP2772 is the ultimate professional grade display for the most demanding color-critical applications.
