The ViewSonic PJ-WPD-200 USB wireless adapter provides added convenience and flexibility to your projection needs. With the PJ-WPD-200, you can wirelessly project and you can use your Android or iOS devices to wirelessly stream content to a projector. Equipped with 2T2R MIMO, and support for up to 300Mbps, the PJ-WPD-200 delivers high-speed and robust data transmission via the IEEE 802.11b/g/n protocol. In addition, the portable and compact design of the PJ-WPD-200 provides an easy way for users to wirelessly connect their projectors. The PJ-WPD-200 is compatible with USB 2.0, most laptops, and select ViewSonic projectors equipped with ViewSync Advanced Connect Technology (ACT), as well as select ViewSonic PLED models.
