Latest BrilliantColor technology delivers stunning all-digital clarity with life-like color, sharp graphics and outstanding video. The advanced 7-segment color wheel enhances the yellow color performance that is key to accurate and vivid color reproduction.
Bright in virtually any setting with 2,000 lumens
Crisp 2,000 lumen output makes this the perfect choice for family room or home theater
Closed captioning
Integrated closed captioning decoder for the hearing impaired
Control capabilities
Features full RS232 control for seamless integration into your automation system
Full 1080p HD resolution
Enjoy the finest quality in high-definition movies, video and TV
Go green and save
Use the Eco-mode to achieve lower power consumption, reduce overall noise and extend lamp life
Pixelworks high performance PW980 video processor
With full 10-bit color processing, detail enhancement technology and motion adaptive de-interlacer for crisper, sharper images
Stay connected
Supports multiple video timing formats from SD (NTSC, PAL & SECAM) to HD 1080p
Ultimate display source flexibility
Two HDMI 1.3 inputs with HDCP compliance and component video input provide full connectivity in a customized home theater installation
ViewSonic Pro8200 - DLP projector - black
DLP projector - 1080p
Built-in Devices
Stereo speakers
Brightness
2000 lumens
Contrast Ratio
3000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Bulb type
230 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type B , 1 x microphone - mini-phone 3.5 mm
Lens cover, remote control
1 x VGA cable , 1 x HDMI cable
Security Features
Password protection
FCC Class B certified, UL, C-Tick, cUL, NOM, TUV S, CB, CCC, PSB, RoHS, WEEE, GOST-R, ICES-004, UkrSEPRO
