With 2.4" LCD color screen and built in Lith-ion battery this scanner has true 'stand alone' capability. It also allows you to scan 110 negatives as well as the usual 35mm.
Convert all your old negatives and slides direct to SD Card. No PC or Mac Required, but also PC and Mac compatible. With added convenience of full colour 2.4" LCD screen. Comes with bundled 2GB SD.
Transfer 35mm slides and 35mm & 110mm negatives onto an SD card with the standalone VFS-008 Smartfix scanner.
