This clamp mount is the ideal accessory for mounting your cellular phone safely and securely to handlebars or bars. The strong and robust clamp with rubberized teeth will firmly hold the phone in place. It is easy to position and allows you to use your device handsfree. This mount accessory is versatile and ideal for biking, boating, sailing, outdoor pursuits, roll bars and roll cages.
