The wireless M7 Mode water resistant speaker from Veho features a slim high quality retro design coupled with superior sound quality, it allows you to stream your music, or charge your smartphone wherever you are.
Connect your wireless Bluetooth device, such as your smartphone, tablet or MP3 player, and enjoy the M7 Mode's 20 watts of high fidelity sound for up to 10 continuous hours, thanks to the powerful 1300 mAh built-in rechargeable battery.
The dual acoustic drivers coupled with the 2 powerful 10 W speakers to give your music a deep 20W bass audio spectrum. The Veho M7 Mode is also equiped with pre-set equalizer controls, to give the speaker a bass boost and support virtual 3D playback.
The Veho M7 Mode's slim retro design with gun metal gray housing and leather carry handle radiate class making it a perfect addition to any home. You don't need to worry about taking your speaker to the pool or the beach with the IPX4 rated housing, meaning that it will keep it safe from splashing water and dust.
The M7's slim lines are designed for portability making it the perfect speaker to take with you on your travels and with the rear of the M7 is equipped with a USB port, you can use your speaker as a power bank. Simply plug in your device into the USB port to give it some extra juice.
