The Pro handle bar mount allows you to fix your micro DV camcorder to your cycle/motorcycle/rollbars securely and reduce vibrations when recording. Its clamping mechanism and foam insert is designed to reduce vibration as well as securely attach the muvi in almost any position. The adjustable mounting ratchet allows you to angle the muvi in any direction to capture the best footage possible.
