Pebble Pro 13200Mah portable battery pack charger for all mobile devices & notebooks - The new Pebble Pro is the big brother of the popular Pebble XT.
It is frustrating when your device runs out of battery life when you are away from a power source. The pocket size Pebble portable battery pack charges your device when needed. The Pebble will charge most popular portable devices such as iPods, iPhones, digital cameras, camcorders GPS, PSP, Nintendo plus many more.
- Massive 13200Mah capacity capable of extending all popular laptops/netbooks/tablets upto 3.5amp by minimum 2 to 5 hours usage time (Dependent on device specification)
- 10 Connectors for most popular Laptops/Netbooks/Notebooks and 4 Phones connectors for iPhone/Blackberry/Smartphones/other portable devices
- Auto shutoff mode to protect against short circuit,over-current,over-charging,and over-discharging
- Dual port charging for laptop and phone at the same time
- Ships with multi region main charging adapter perfect for recharging on the move whatever country you are in
Not only does it charge all popular mobile devices like the iPhone, Blackberry, iPad it also charges most common notebooks and netbooks.
With it's massive 13200mah rating it can charge an iPhone over 10 times and with 4 different mobile phone tips and 10 different notebooks tips (16v & 19v at 3.5A output) it is truly universal.
