Speaker - 2 x 10 Watt - 60 - 18000 Hz - <2% THD - 4 Ohm - active
Speaker battery rechargeable
9.3 cm
Dimensions - Diameter
17 cm
550 g
Speaker - for portable use
Enclosure Material
Aluminium
Speaker System
Speaker Type
Active
Nominal Output Power
20 Watt
Frequency Response
60 - 18000 Hz
Signal-To-Noise Ratio
85 dB
Amplifier
Integrated
Bluetooth 4.0
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x full-range driver , Speaker: 2 x Passive Radiator
Connector Type
Audio line-in (mini-phone 3.5mm)
Audio cable, micro-USB charging cable
Rechargeable
2200 mAh
Run Time (Up To)
15 hours
Recharge Time
4 hours
Diameter
17 cm
9.3 cm
550 g
