The 360° M4 Bluetooth Speaker follows on from the successful VSS-006-360BT 360° M3 Bluetooth Speaker but introduces duel 2 x 2.2 w speaker power and includes a microSD card slot and volume/track control.
The 360° M4 Bluetooth Wireless Speaker remains totally portable standing only 6.5 cm high with a diameter of 5.5 cm and contains a 600 mAh rechargeable battery that allows playback of up to 6 hrs. The M4 also ships with a standard 3.5 mm line in cable to use with any standard non Bluetooth device, mini USB charging cable and also a funky protective carry sock.
Sound output on the 360° M4 Bluetooth Wireless Speaker is doubled boosted by two 2.2 watt speakers and for convenience volume and track control are located on the speaker so you can control your music from the speaker whether you are using Bluetooth wireless or the micro SD port located on the speaker.
