The V7 Mini DisplayPort to HDMI adapter lets you connect a high definition monitor, projector, or LCD that uses a HDMI connector or cable to an Apple MacBook, MacBook Pro as well as other Apple products with a mini DisplayPort. The adapter allows you to view HD content from your Blue-ray players or a cable box on your Apple LED-backlit widescreen monitor. The V7 Mini Display Port to HDMI adapter supports high-resolution video and audio, allowing you to display HD content from external devices on the 27-inch iMac. Simple to use, this small form factor converter makes Mini DisplayPort backwards compatible with your existing HDMI display or projector. No software installation or drivers required providing a simple plug and play solution.
