            Engineered to provide protection for an active mobile lifestyle, UAG brings you the first rugged MacBook Pro 13-inch that meets MIL-SPEC 810G-516.6 drop test standards. The patented composite design fuses a hard outer shell with soft impact resistant bumpers engineered to protect your MacBook Pro 13-inchfrom drop and shock. The unique 1-piece design and soft rubberized bumpers and bottom skid pads provide 360-degree protection from scratches and abrasions. With oversized ports and a low profile design that slips in and out of your bag, access is always fast and easy. Available in a clear translucent color, UAG's rugged and lightweight MacBook Pro 13-inch cases are sure to make you stand out from the crowd whether at work or the next expedition. Compatible with the MacBook Pro 13-inch (4th Gen, 2016-2018) with Touch Bar and Non-Touch Bar Model Numbers: A1708, A1706, A1989.
