Imagine you could reach out and with a light touch, tilt your display anywhere through its range to suit your precise viewing angle. The ease of this is possible thanks to the patented POZIMOUNT tilt counterbalance mechanism. The tilt angle you choose is reliably set or can be changed whenever necessary. POZIMOUNT units can be direct wall fixed or used with any of the ceiling kits, swing-arm wall units or stands and trolleys.
