Back
Refinements
Unicol PLS1X1 Single Swing Arm Wall Bracket For Screens 37-55"
Quicklinx:
97TLWS00
Mfr#:
PLS1X1
Back
This mount lies flat to the wall and also swings out giving high degree of adjustment.
Unicol Panarm PLS1X1 mounting kit - for flat panel
Mounting kit - wall-mountable
Mounting Components
Wall mount, swing arm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
Up to 50"
Max Load Weight
50 kg
Image Colour Disclaimer
The displayed product image may be a different colour
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Up to 50"
Adjustments
Tilt
Max Load Weight
50 kg
Rotating, swivel adjustment
