Designed to handle multiple HD streams in a busy connected home, TRENDnet's high performance AC1200 Dual Band Wireless Router, model TEW-813DRU, creates two concurrent wireless networks - a high performance 867 Mbps Wireless AC network and a 300 Mbps Wireless N network to connect common wireless devices.
Easy Setup
Get up and running in minutes with the intuitive guided setup
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
USB Share Port
Plug in a USB flash or storage drive to share content across the network
Access Control
Encrypted Wireless
For your convenience the router arrives pre-encrypted with its own unique password
Guest Network
Create a secure, isolated network for guest internet access only
Parental Controls
Control access to specific websites or types of content
Next Generation Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home
Simultaneous Dual Band
High speed 867 Mbps Wireless AC + 300 Mbps Wireless N
Gigabit Ports
Gigabit ports extend high performance wired connections
Wireless Coverage
Extensive wireless coverage with MIMO antenna technology
Backward Compatible
Compatible with legacy wireless devices
Targeted Beamforming
Increased real-time performance by directing stronger wireless to your specific location
- For maximum performance of up to 867 Mbps use with an 867 Mbps 802.11ac wireless adapter.
** Maximum wireless signal rates are referenced from IEEE 802.11 theoretical specifications. Actual data throughput and cov-erage will vary depending on interference, network traffic, building materials and other conditions.
