Day or night, the DrivePro 100 Car Video Recorder is your most reliable eyewitness on the road. With a built-in battery, the recorder gives you an extra 30 seconds of recording in case of power failure, offering maximum assurance. The DrivePro 100's high-quality wide angle 6 glass lenses can capture snapshots and clear Full HD footage for display on a bright 2.4" color LCD screen. Easy to operate, the DrivePro 100 includes the Auto Power On/Off feature and the free-to-download DrivePro Toolbox for Windows for users to easily play the recorded videos on their computer.
Protecting You Day and Night
Featuring a large F/1.8 aperture and high-quality camera lens, the DrivePro 100 can automatically adjust to different lighting conditions to capture all details of an incident, including license plates, during either daytime or nighttime.
Built-in Battery to Ensure Uninterruptible Recording
With a built-in Li-Polymer battery, there's no need to worry about sudden power failure caused by traffic incidents. When the car loses power, DrivePro 100 continues to record for up to 30 seconds to ensure the important evidentce is captured. Alternatively, the DrivePro 100 can be manually activated to record up to 30 minutes on a fully charged battery without a power supply.
Convenient Snapshot Function
The convenient snapshot feature allows you to take photos while recording video. During an incident, you can also remove DrivePro 100 from the vehicle to capture collision damage on the spot.
Sharp and Smooth Images
The DrivePro 100's camera integrates a wide 130° viewing angle and a Full HD imaging sensor for clear and smooth 1080p (30fps) recordings. The 6 glass lenses plus 1 infrared filter lens are designed to prevent fogging from heat generated during extended recordings and to ensure your whole trip is recorded in high clarity.
Record Every Critical Moment
If the DrivePro 100's built-in G-Sensor detects an impact during recording, it will instantly trigger Emergency Recording mode up to 1 minute (30 seconds before and after the incident). Alternatively, you can also activate emergency recording mode manually by pressing the red emergency button; this is useful when situations occur outside the vehicle where you need to collect evidence in case of a fraudulent claim or lawsuit. Video files recorded in emergency mode are protected from being overwritten.
Built-in battery to ensure uninterruptible recording
With a built-in Li-Polymer battery, there's no need to worry about sudden power failure caused by traffic incidents. When the car loses power, DrivePro 100 continues to record for several seconds to ensure the important evidence is captured. Alternatively, the DrivePro 100 can be manually activated to record up to 30 minutes on a fully charged battery without a power supply.
Convenient snapshot function
Sharp and smooth images
The DrivePro 100's camera integrates a wide 130° viewing angle and a Full HD imaging sensor for clear and smooth recordings. The 6 glass lenses plus 1 infrared filter lens are designed to prevent fogging from heat generated during extended recordings and to ensure your whole trip is recorded in high clarity.
Record every critical moment
Transcend DrivePro 100 - dashboard camera
Dashboard camera - 1080p
Memory Card Slot
microSD card
Sensors
Gyro sensor
Sensor Resolution
3.0 Megapixel
Lens System
Wide-angle lens f/1.8
Display
LCD display - 2.4"
Incident Detection
G-Sensor
Supported Battery
Li-Polymer rechargeable battery - 470 mAh (included)
USB 2.0
6.31 cm x 3.44 cm x 6.83 cm
72.6 g
Sensor Resolution
3.0 Megapixel
Sensor Qty
1 CMOS
Widescreen Video Capture
Optical Sensor Type
CMOS
Sensors
Gyro sensor
Digital Video Format
H.264, MOV
USB 2.0
Lens System
Max View Angle
130 degree(s)
Lens Construction
6 elements
Additional Features
Additional Features
Audio recording, built-in speaker, auto power save, takes photos while film recording
Dashboard Camera Features
Incident Detection
G-Sensor
Display
2.4" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0
Software
Software
Drivers & Utilities, Transcend DrivePro PC Tool
Car power adapter, suction cup mount
Battery Type
Lithium polymer - integrated
Details
Battery Life Details
Video recording - 0.5 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card
16 GB microSDHC
Memory Card Max Supported Size
32 GB
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps
