TP-LINK AV600 Gigabit Powerline Adapter TL-PA6010 turns your existing electrical circuitry into a high speed network with no need for new wires or drilling. No configuration is required, simply plug your adapters into your power sockets to establish networking infrastructure in a flash. With speeds of up to 600Mbps, TL-PA6010 can transmit multiple HD streams and even 3D movies to every room, making it a great choice for an easy to build multimedia entertainment network.
Up to 600Mbps for up to 300 Meters
With advanced HomePlug AV technology, TL-PA6010 provides users with stable, high-speed data transfer rates of up to 600Mbps on a line length of up to 300 meters. Together with its built-in AES encryption, the TL-PA6010 is a great choice for a whole-home solution to connect all network compatible devices, from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.
Multiple HD Streams
Up to 600Mbps powerline speed in tandem with a Gigabit RJ45 Ethernet port, ensures the smooth transmission of multiple HD video streams.
Ultra-compact
With its new ultra-compact housing design, TP-LINK's TL-PA6010 is one of the smallest Powerline adapters in the world.
Reduce Power Consumption by up to 80%
The TL-PA6010, a new-generation of Powerline adapter, with its practical design and sophisticated Power-Saving Mode consumes less power when compared with existing Powerline adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" mode to "Power-Saving" mode that will reduce its energy consumption by up to 80%*.
*Actual data will vary in different network conditions and environments.
Plug and Play
You can setup a hassle-free Powerline network within minutes with TP-LINK Powerline adapters, just plug in and play. Also, the adapters' "Pair" buttons can be utilized for securing or managing multiple Powerline adapters in your home Powerline network.
*Note: Powerline adapters must be deployed in sets of two or more.
Supports QoS for Advanced Multi-media Optimization
The Quality of Service (QoS) function prioritizes the bandwidth requirements of data traffic. Users can choose which type of traffic they will use -- Internet, Online Gaming, Audio or Video or Voice over IP, and the QoS functions will guarantee clear, instant reproduction of that application, even when other applications are running on the network at the same time.
