            Window/Door Safeguard - Monitors the opening & closing of windows, doors, cabinets, the fridge, or the mailbox in real time.
Instant App Notification - Is your parcel locked away? Find out immediately with instant notifications.
Smart Action Support - Connect the actions with other smart devices for a welcome return home.
Easy Installation - Mount to nearly any surface with included 3M adhesive. Supports up to 15mm gap
Great Compatibility - Just one part of the integrated Tapo ecosystem.
Tapo Hub Required – Tapo H100 (sold separately).
Know the Status - Stop wondering if you closed all your windows after leaving home. Check on your doors and windows at a glance with the Tapo app.
Long-Lasting Performance - 2-year battery life provides long-lasting convenience. Receive notifications from the Tapo app when the batteries are low and need changing.
All in One App - Experience your next-level smart home with the Tapo line all in a single app. Create a more secure, convenient, and comfortable living space for you and your loved ones.
Box Contents
- Tapo T110
- Quick Start Guide
- Battery CR2032 x1
- 3M adhensive
