            Kasa Smart Wi-Fi Light Bulb, Dimmable
Control the mood with your Kasa Smart dimmable light bulb.
Dimmable
With a dimming range from 1% up to 100%, the Kasa Smart Wi-Fi Light Bulb, Dimmable helps you set the right brightness for any mood or activity.
Grouping
Use the Grouping feature on the Kasa Smart app to combine your devices together for unified control with one single tap on your smartphone. Combine your living room bulbs, plugs and light switches together for an easier way to turn them on when you get home.
Control From Anywhere
Control your Kasa Smart lighting from anywhere with the highly-rated Kasa Smart app (available for iOS, Android). Make sure you turned your bedroom lights off from the office or turn your living room lights on before you get home.
Voice Control
Use simple voice commands to control all of your Kasa Smart light switches or light bulbs with any Alexa, Google Assistant or Microsoft Cortana smart speaker. Turn on kitchen lights when your hands are full, let your voice assistant know to dim your lights, even turn off hallway lights as you're walking to bed.
No Hub Required
Connect your Kasa Smart dimmable light bulb directly to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Energy Efficient
The Title 20 and Energy Star certified light bulb reduces consumption by up to 80% without losing brightness or quality, while saving you money.
