- 10G Lightning-Fast Uplink: 4× 10 Gbps SFP+ slots enable high-bandwidth connectivity and non-blocking switching capacity.
- Gigabit Speeds: 24× gigabit RJ45 ports offer high-speed and reliable connections to other switches and devices.
- Integrated into Omada SDN: Zero-Touch Provisioning (ZTP), Centralised Cloud Management, and Intelligent Monitoring.
- Centralised Management: Cloud access and Omada app for ultra convenience and easy management.
- Static Routing: Helps route internal traffic for more efficient use of network resources.
- Robust Security Strategies: IP-MAC-Port Binding, ACL, Port Security, DoS Defend, Storm control, DHCP Snooping, 802.1X, Radius Authentication, and more.
- Optimize Voice and Video Applications: L2/L3/L4 QoS and IGMP snooping.
- Standalone Management: Web, CLI (Console Port, Telnet, SSH), SNMP, RMON, and Dual Image bring powerful management capabilities
The TL-SG3428X provides a switching capacity of 128 Gbps, allowing for rapid data transmission across your network. This feature ensures that heavy traffic loads can be managed effectively without any interruptions.
Featuring 28 ports, including 24 for 10/100/1000 Mbps and 4 for 10 Gigabit SFP+, this switch supports a range of network configurations, accommodating various devices and network setups.
With a packet forwarding rate of 95.23 Mpps, the TL-SG3428X manages high workloads efficiently, making it ideal for both small and large networks.
This model incorporates multiple security features including DoS attack prevention, VLAN support, and Access Control List (ACL) capabilities, ensuring your network remains protected against various threats.
Offering a variety of remote management protocols like SNMP and Telnet, the TL-SG3428X allows for easy monitoring and configuration, streamlining the management of network resources.
- TP-Link JetStream TL-SG3428X - V1 - switch - 28 ports - Managed - rack-mountable
- Switch - 28 ports - Managed
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 4 x 10 Gigabit SFP+
- Performance
- Switching capacity: 128 Gbps , Packet forwarding rate: 95.23 Mpps
- Capacity
- Priority queues: 8 , VLAN groups: 4000
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD, MSTP, RSTP, STP
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI, ICMP, DHCP, RSTP
- Flow control, VPN support, BOOTP support, ARP support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, sFlow, DHCP snooping, ACL support, QoS, DHCP server, MLD snooping, Cable Diagnostics Function, bandwidth control, DLDP support, fanless, LLDP support, DHCP relay, LACP, Port Security, MVR, NDP, port isolation, 12MB packet buffer, CoS, SP, GVRP, 802.1x authentication, cloud managed, DSCP support, IP source guard, ARP inspection, BPDU, dual image support, SDN, AAA, LLDP-MED, VLAN group, guest access, ZTP, EEE, BPDU Filter, WRR, HOL Blocking Prevention, loopback detection, Advanced QoS, MAB, security slot (Kensington security lock compatible)
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 18 cm x 4.4 cm
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SSL 3.0, TLS 1.2
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Status Indicators
- Status
- 24 x 1000Base-T RJ-45 , 4 x 10GBase-X SFP , 1 x console RJ-45 , 1 x micro-USB console
- Power Device
- Internal power supply
- Voltage Required
- 23.6 Watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- FCC, RoHS
- 44 cm
- 18 cm
- 4.4 cm
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
