HD Pan/Tilt Wi-Fi Camera With Night Vision
- 720p HD Imaging - HD resolution provides sharper, clearer images
- Pan / Tilt - See up to 360 degrees horizontally and 150 degrees vertically.
- Night Vision - Know what’s happening when it’s dark, with up to 26 feet of night vision.
- Motion & Sound Detection - Receive push and email notifications when motion or sound is detected.
- 2-way Audio – Start 2-way audio with ease to communicate with your family instantly
- Micro SD Card Storage - Save your videos and images easily thanks to an integrated SD slot
- tpCamera App - Use the tpCamera app to access feeds from anywhere, at any time
Smooth Pan/Tilt For a Better View
The NC450 is your favorable companion that meets your home and office surveillance needs, keeping you in touch with what matters most. With its smooth and durable Pan/Tilt of up to 300/110 degrees, you can turn the camera to almost any position you want and watch over a wider area of your home.
Excellent HD Clarity
With glass camera lens and a 1/4" progressive scan CMOS sensor, you can capture 720p high definition vivid video and crystal-clear stills. The infrared LED helps the camera to get night vision with excellent image quality.
Peace of Mind at Night
The camera will automatically switch to a sharp monochrome video stream at night and provide clear, detailed images at ranges of up to 26 feet in total darkness. You can easily know what’s happening during the night.
Instant Alert for Important Events
The NC450 can send you automatic push and email notifications when movement or sound is detected and keep you aware of what’s going on immediately. The integrated Micro SD Card slot supports up to 32GB storage, allowing you to save pictures and videos for memorable moments.
Communicate with Ease
With excellent 2-way streaming audio, you can communicate with your family instantly whenever you want.
Convenient Remote Access for Daily Monitoring
The tpCamera app allows you to take control of your Wi-Fi camera anywhere and anytime with internet access. You can easily monitor your room, record video, and snap pictures with the touch of your fingertips.
