WiFi 7 Mesh speed
9.3 Gbps Tri-Band WiFi 7 – 5765 Mbps (6 GHz) + 2882 Mbps (5 GHz) + 688 Mbps (2.4 GHz)
2.5 Gbps Wired Connections
4× 2.5 Gbps ports ensure max flexibility and boosted throughput
Wireless and Wired Combined Backhaul
Connects a wireless and wired backhaul with each unit simultaneously to improve overall throughput and reduce latency
Multi-Link Operation (MLO)
Simultaneously send and receive data across different bands and channels to increase throughput, reduce latency, and improve reliability
320 MHz Channels
Double the bandwidth and enables many more simultaneous transmissions at the fastest possible speeds
Works on the 6 GHz Band
Minimizes congestion with greenfield spectrum, delivering robust high-speed connections
TP-Link HomeShield
Provides comprehensive network protection, robust parental controls, and real-time IoT security
Universal Compatibility
Backward compatible with all WiFi generations and works with any internet service provider (ISP) and modem
Compatible with New iPhone
The new iPhone 16 and 16 Pro now support the latest WiFi 7 standard, while TP-Link WiFi 7 Mesh delivers the speed and performance of this next-gen WiFi technology
